It is currently Tue Aug 19, 2025 10:01 pm
PostPosted: Fri May 30, 2014 5:10 am
First name: Theo
Last Name: Delaca
City: Fbks
State: Ak
Zip/Postal Code: 99712
Pretty much as the title states, I'm wondering what kind of glue people would recommend for gluing a wooden pick guard to a french polished top.
PostPosted: Fri May 30, 2014 5:29 am
I am not a huge fan of pick guards, my hunch is the added weight is not a plus for sound quality/production - but seems it matters not since so many guitars have them. Plus for some playing styles they are a must have -- but Willey's guitar in on the cover of AG mag looks crap but still going.
Even Elmer's sticks well to (wax free) shellac -- I'd use thin double sided tape if only to help prevent sound hole cracks that could occur if the pick guard wood and the sound-board wood expand and contract at different rates with humidity change.
Ken Cierp
PostPosted: Fri May 30, 2014 5:33 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
The same adhesive sheet that is used on lacquer and other guitar finishes works for plastic pickguards on a FP top so I don't see why it wouldn't work here. I would completely finish all sides of a wooden pick guard before installing to minimize movement.
Brian
PostPosted: Fri May 30, 2014 7:05 am
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
+1 on the pressure-sensitive adhesive sheets. I've used the 3M product that stewmac sells: http://www.stewmac.com/shop/Pickguards/Pickguard_materials/Pickguard_Adhesive_Sheet.html, but LMI sells something similar (if it's not identical): http://www.lmii.com/products/mostly-not-wood/pickguard-material/transfer-adhesive Take a look at Robbie O'Brien's video on how to use this properly: http://www.youtube.com/watch?v=2kVRmu5_k8I
Where I've done a wood pickguard (like the one on my avatar), it has always matched a fingerboard and/or bridge, so I've treated it the same way with a bit of lemon oil after installation. No other finish, but seems to work fine.
PostPosted: Fri May 30, 2014 8:14 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
I/ve used fish glue on a small spalted sycamore pickguard.intended for a tenor pineapple uke.
PostPosted: Fri May 30, 2014 8:40 am
+2 for the pressure-sensitive adhesive [:Y:]
Also - do you know the "hinge" method using masking tape to make a hinge to locate the guard when installing - works great.
PostPosted: Fri May 30, 2014 10:11 am
Last Name: Russell
State: Michigan USA
Here is a "Hack" for ya... beehive
How about Velcro?
Then you can change your pick guard to suit your mood... laughing6-hehe
PostPosted: Fri May 30, 2014 10:19 am
First name: joseph
Last Name: sallis
City: newcastle-upon-tyne
State: tyne and wear
Zip/Postal Code: ne46xe
Country: UK
I'm wondering the same question at the moment. But like ken I am concerned about the different expansion rates of contrasting wood causing a crack on the soundboard. I did wonder about rather than gluing the whole of the wooden pick guard on, having extremely thin post-like shims so that there was only a few points of contact between the sound board and the pick guard.
Does this sound like a sensible idea?
We are all in the gutter but some of us are looking at guitars.
PostPosted: Fri May 30, 2014 11:09 am
fwiw I glue my wooden guards onto plastic then use the adhesive sheets for reasons stated.
PostPosted: Fri May 30, 2014 2:38 pm
First name: Theo
Last Name: Delaca
City: Fbks
State: Ak
Thanks for the tips
it seems like the pressure sensitive sheets might be the way to go
Hesh-I recall seeing the tape hinge on a Dan Erlwine video a while back, I'll have to go back to refresh my memory- thanks
jfmckenna- what kind of plastic sheet? how thin?
I've never done a pickguard before, and have not really thought much about them, hadn't even considered the expansion contraction issue :o. I've mostly built ukes up till now and am moving in the guitar direction, even then I'm not that fond of them but this time it might be a good option to cover a cosmetic issue on the bottom edge of a rosette. That, and my son who will be playing it a lot wanted one, I wasn't originally planning it, but when the time came it seemed like an easy out for a poorly routed rosette channel :roll: . I like the fact that this is one choice I don't have to make right away, who knows maybe I'll bag the pickguard in the end, I'll make it and see if its better with or without. This is for a guitar I have going for the local woods building chlalange
PostPosted: Fri May 30, 2014 2:44 pm
I don't remember how thin the plastic sheet is but it was thinnest I could get in black. The black makes a nice line. Most of the wood I use was a very thin walnut burl.
